AP-515 LACP
This thread has been viewed 71 times
  • 1.  AP-515 LACP
    Posted Feb 09, 2023 02:41 AM
    our customer with Aruba AP 515, asked to connect it with two Eth, to obtain more capacity.
    We connectet it to an Aruba 6000 switch. The switch port has been configured in lag, with lacp-mode active. Then we passed the vlan into the lag interface.
    When the AP is connected with two cables, we can see from the switch and also from AP serial interface, that the LAG is working correctly at 2 Gb.
    Access points look working correctly, but when only some clients are able to connect, while other present problems to obtain an ip address, from the custom firewall.
    If we connect the AP to the LAG with only one cable, there aren't problems, all clients can connect correctlly and obtain immediatly an IP address.
    The AP is always connected to the LAG, but the issue is present only when it is connected with two cables.
    Some idea of what could be the problem? Am I missing something in my configuration?
    Thanks!
    Kind regards.
  • 2.  RE: AP-515 LACP
    Posted Feb 09, 2023 09:13 AM
    Does this help? https://www.arubanetworks.com/techdocs/ArubaOS_86_Web_Help/Content/arubaos-solutions/access-points/lacp-supp.htm
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: AP-515 LACP
    Posted Feb 09, 2023 09:46 AM
    Hi DB86,
    I know that document, but it didn't help.
    I have to add that the AP are managed in Instant mode.
    Thank you.
  • 4.  RE: AP-515 LACP
    Posted Feb 09, 2023 09:54 AM
    Have you checked this?
    Enabling Static LACP Configuration
    When Instant APs connect to switches which have the LACP capability, the LACP feature does not work as expected. To enable a static LACP configuration, new commands are introduced.
    Instant APs support the dynamic LACP configuration according to a peer switch. When the peer switch enables LACP configuration, the Instant APs form the LACP. Users can enable, disable, and remove the static LACP configuration in the Instant AP. When the Instant AP boots up, it forms the LACP according to the static configuration.
    The static LACP mode is supported on 220 Series, 270 Series, 320 Series, 330 Series, 340 Series, 510 Series, 530 Series, and 550 Series access points.
    To enable the static LACP mode on Instant APs:
    (Instant AP)# lacp-mode enable
    To disable the static LACP mode on Instant APs:
    (Instant AP)# lacp-mode disable
    Verifying Static LACP Mode
    To verify the static LACP configuration, execute the following command in the Instant AP CLI:
    (Instant AP)# show ap-env
    Antenna Type:Internal
    per_ap_ssid:1234
    per_ap_vlan:abc
    lacp_mode:enable
    Dustin Burns
  • 5.  RE: AP-515 LACP
    Posted Feb 09, 2023 10:14 AM
    Yes, I tested both the possibilities, static and dynamic lacp, but with the same results and problem.
    In my case the lacp was correctly formed in both cases, but wireless network was working fine only when the APs were connected with only one cable.
  • 6.  RE: AP-515 LACP
    Posted Feb 09, 2023 12:25 PM
    What benefit are you expecting to obtain from utilizing a LAG that isn't also available through active/standby connectivity?  Unless you are testing under lab conditions you will likely never reach a wireless throughput that would saturate a single 1 Gbps connection.
    Carson Hulcher, ACEX#110
  • 7.  RE: AP-515 LACP
    Posted Feb 10, 2023 02:05 AM
    Hello Carson,
    customer bought the APs from a network "consultant", than asked us to configure it, following the consultant request. So he expect to see a 2Gb Lag and the wifi working.
    Also because in the AP datasheet there is this sentence " Link aggregation (LACP) support between both network ports for redundancy and increased capacity".
    Why Aruba affirms that in the datasheet, if  as you said "it isn't available through active/standby connectivity"?
    Thanks!
  • 8.  RE: AP-515 LACP
    Posted Feb 10, 2023 08:57 AM
    If you will re-read my reply you'll notice that what I asked was "What benefit are you expecting to obtain from utilizing a LAG that isn't also available through active/standby connectivity?"  Nothing about that says we don't support LACP.
  • 9.  RE: AP-515 LACP
    Posted Mar 31, 2023 05:52 AM
    Why do you affirm that   "you will never reach a wireless throughput that would saturate a single 1 Gbps connection"?
    If I aggregate all the wifi clients traffic, couldn't it be superior to 1Gbps, if the uplink allow it?
  • 10.  RE: AP-515 LACP
    Posted Mar 31, 2023 09:37 AM
    Very unlikely.  Unless you are operating that AP and the two clients (one for each band) inside a lab environment so that you can get the perfect conditions, the likelihood of you ever exceeding 1 Gbps on the AP uplink is extremely low...and if you did, the chances of you maintaining that throughput is even lower.
  • 11.  RE: AP-515 LACP
    Posted Mar 02, 2023 12:10 PM
    Edited by Steinar Grande Mar 02, 2023 12:12 PM
    Not sure if this apply for you, but in a dual Conductor/controller env,
    this I a known flaw for the 515,
    Just disable the LAG once and for all, an check again.
    There will be no performance impact for clients.
    (There is no need for LAG in any Aruba dual eth. AP's)
    Steinar
