AP-535 won't start led status 9 times green 1 times red
This thread has been viewed 53 times
  • 1.  AP-535 won't start led status 9 times green 1 times red
    Posted Jan 30, 2025 08:16 AM
    Hello all,
    Hopefully you can help me with the problem below.
    We have two mobility controller 7210, version 8.11, in our environment. primary and secondary controller.
    We have different types of AP, both the 535 and 635.
    Now I have an AP 535 that won't start.
    Normally we grab an AP, connect it to the network, wait 10 minutes and the AP is added to the access devices list.
    Only this AP does not appear in the list.
    Regarding the LED status, this AP gives a green LED blinks 9 times and then a red LED blink 1 time.
    What can I do to check what is going on with this AP?
    I have also tried to make the AP factory default, but this did not help.
    Thank you in advance.
  • 2.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Jan 30, 2025 09:31 AM
    Best method is to connect a console cable to the AP and monitor the boot process.  Open a TAC case if you don't have the cable.
    Carson Hulcher, ACEX#110
  • 3.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Jan 30, 2025 09:34 AM
    I have a console cable, how can you connect this with the AP and login ?
    Can you use putty?
    And what is the login credentials and the command to monitor it ?
    Thank you.
  • 4.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Jan 30, 2025 09:44 AM
    Any terminal program that supports serial connectivity can be used.
    You're wanting to watch the boot process to see if anything sticks out as useful.  If you don't know what might be useful, open a case with TAC.
  • 5.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Jan 31, 2025 03:30 AM
    Original Orange console cable AP-CBL-SERU connect to microusb console port. Usually Windows will already have the correct driver. If not, go to networkingsupport.hpe.com and download USB driver. Use whatever terminal emulation program you like. Speed is 9600 8 N.
    No credentials are needed for monitoring boot process.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 6.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Jan 31, 2025 03:45 AM
    Is the fabric number of the cable JY728A ?
    This is the one i can order with our supplier.
    HPE Aruba Console Adapter Cable (JY728A) kopen
    Thank you.
  • 7.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Jan 31, 2025 04:21 AM
    Yes. This is the correct cable.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 8.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Feb 07, 2025 03:08 AM
    Edited by Jordy de Kleijn Feb 07, 2025 03:08 AM
    The cable was deliverd and this is the output of the AP:
    Hit <Enter> to stop autoboot:  0
    Booting OS partition 0
    Checking image @ 0x0
    APBoot 2.5.3.10 (build 74666)
    Built: 2020-03-12 at 17:05:54
    Model: AP-53x/555
    DRAM:  2 GiB
    Flash: Detected MX25U6435F: total 8 MiB
    NAND:  256 MiB
    Power: 802.3bt POE, port0
           No POE, port1
    UBI error: ubi_read_volume_table: the layout volume was not found
    UBI error: ubi_init: cannot attach mtd4
    UBI error: ubi_init: UBI error: cannot initialize UBI, error -22
    UBI init failed
    Net:   PHY8 - Loading firmware ................ done
           PHY7 - Loading firmware ................ done
           eth0
    Radio: ipq8074#0, ipq8074#1
    Reset: cold
    FIPS:  passed
    Can you tell me what I can do to revive the AP.
  • 9.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Feb 07, 2025 10:23 AM
    You'll want to open a case with TAC on that one and probably get an RMA.
  • 10.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Feb 07, 2025 07:22 PM
    looks like flash corruption of some kind.
  • 11.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Feb 10, 2025 02:17 AM
    It seems so indeed. Can you tell me how to make a case in TAC? Never done that.
  • 12.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Feb 10, 2025 02:25 AM
    Hi @Jordy de Kleijn
    Go to networkingsupport.hpe.com and select Case Management tile
    select Start a New Case tile
    and fill required info there.
    Here is a TAC User Guide.
    If you can't access Networking Support portal, onboard yourself to it and create a case.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 13.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Feb 12, 2025 04:55 AM
    This is strange, when I want to enter my serial number to make a case. I get the following error:
    Invalid time value
    Serial number not found. ApolloError: Invalid time value
    What can I do now ?
  • 14.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Feb 12, 2025 05:00 AM
    Go to https://support.hpe.com and in warranty check enter your serial number to check, if it is correctly registered in the system.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 15.  RE: AP-535 won't start led status 9 times green 1 times red
    Posted Feb 13, 2025 05:10 AM
    Thx, this is working indeed. Yesterday and the day before it didnt work.
    I'll check for the warrenty.
