  • 1.  AP-555 not broadcasting SSID. Radios off
    Posted Mar 02, 2023 04:20 PM
    • First: AP-555 not broadcasting SSID. Radios off
    • Second: Can't get URL access to AP-555 after upgrade to ArubaOS_Scorpio_10.3.1.3_85763
  • 2.  RE: AP-555 not broadcasting SSID. Radios off
    Posted Mar 02, 2023 04:36 PM
    if you are running AOS10, like you do, you need Aruba Central.
  • 3.  RE: AP-555 not broadcasting SSID. Radios off
    Posted Mar 04, 2023 04:45 AM
    Thanks for your replay
    But i need to work as Instant On, Can't get URL access after upgrade to ArubaOS_Scorpio_10.3.1.3_85763
    And when i need to downgrade give me this message
  • 4.  RE: AP-555 not broadcasting SSID. Radios off
    Posted Mar 04, 2023 03:41 PM
    you can download the desired Instant firmware and if you have console access you can tftp it from there and downgrade it.
    alternatively, you can get a Central eval account add it to your account and use Central to downgrade it to instant 8.x
  • 5.  RE: AP-555 not broadcasting SSID. Radios off
    Posted Mar 08, 2023 05:34 AM
    It will usually take some time. What does the command 'show upgrade' or 'show log upgrade' tell? Could be that the file cannot be retrieved from the TFTP server. If you have a web server / HTTP, I would put the upgrade file on there. TFTP and large files have some issues on performance and reliability depending on the server software used. HTTP is just more reliable in my experience.
