  • 1.  AP 574 antenna question
    Posted Nov 10, 2024 08:52 PM
    Hi teams
         Can the 574 antenna be connected to only one ANT-2x2-5010?
         Only connect the following two interfaces:
    leo ma
  • 2.  RE: AP 574 antenna question
    Posted Nov 11, 2024 04:11 AM
    You could do that but you stripe down the 4x4 capable AP to an 2x2 AP. Be sure to terminate the no used Antenna connections.
    But the question would be why you don´t use the AP-565 instead. This is an 2x2 Outdoor AP.
    What is the exact use-case and why don´t you install 2 x AP-ANT-5010 to get full RF power?
  • 3.  RE: AP 574 antenna question
    Posted Nov 11, 2024 07:05 AM
    Thank you very much for your reply,Because the sales pushed 574, but the price of the antenna exceeded expectations, so only a 2*2 was used,
    leo ma
  • 4.  RE: AP 574 antenna question
    Posted Nov 11, 2024 04:13 PM
    If you are using only two of the connections on the AP-574 then you MUST install 50 Ohm terminators on the unused ports to prevent damage to the radios.  You should really be returning the AP-574 and replacing with either an AP-575 or AP-565.
    Carson Hulcher, ACEX#110
  • 5.  RE: AP 574 antenna question
    Posted Nov 12, 2024 08:36 PM
    OK, thank you very much
    leo ma
