  • 1.  AP-585 LED status
    Posted Aug 13, 2024 04:07 PM
    Quick question as the 580 series install guide does not mention this. These new APs provisioned are showing their LED status as green with a quick off every couple of seconds.
    It reminds me of some older APs which would do this if they were connected at 100mb.
    PoE is delivering 45w and ports are properly connecting at 1000mb.
    Any ideas?
  • 2.  RE: AP-585 LED status
    Posted Aug 13, 2024 06:06 PM
    AP is operational?  WLAN broadcasting?
    Carson Hulcher, ACEX#110
  • 3.  RE: AP-585 LED status
    Posted Aug 13, 2024 09:45 PM
    As noted, this LED indicator isn't documented in the installation guide, I think that will be fixed in the future.
    Green LED with pattern of 2.5 seconds on, 0.5 seconds off, indicates a fault on radio 0.  That may be configuration, DRT, assigned regulatory domain, or failed hardware.
  • 4.  RE: AP-585 LED status
    Posted Aug 14, 2024 09:53 AM
    Thank you.
    Right now, I have four in a bench, next to each other as we were testing the configuration and switches feeding them. I'll try powering only one, and if it persists, I'll contact TAC.
