When the setting is automatic, only a certain percent of flex radios will be converted to 6 GHz and only if RF for 5 GHz and 2.4 GHz (in that order) are determined to be covered adequately.
Original Message:
Sent: Nov 08, 2024 08:33 AM
Subject: AP-605 6GHz 6GHz not enabled
605H APs only have two radios. They cannot do 2.4, 5 and 6GHz at the same time.
You can select which radios are used in the AP System profile at Flex Dual Band Mode. Automatic keeps that up to Airmatch if i understand it correctly.
I do not know though if changing this setting will have an impact on tri-radio APs in the same AP Group.
Original Message:
Sent: Nov 08, 2024 07:51 AM
Hello experts,
We just received our AP-605s and noticed that when we powered up one device, it was not broadcasting 6GHz
We assigned the AP to the same AP group as that of AP-635s and even AP-634s (6GHz enabled but not operational)
Wanted to know if AOS 8.12.0.0 supports the AP-605 or we need to upgrade to some other image.
Alex
AP-605
AP-634
