  • 1.  AP-605H - 6 GHz will not activate (8.12.0)
    Posted Jun 21, 2024 10:31 AM
    We are installing a number of AP-605Hs.  Running 8.12.0.  We know that we can only uses 2 of the 3 bands, but we have been unable to get 6GHz to activate even if we turn off both 2.4 and 5.  What are we missing?  Thanks in advance.
    Rob Jones
    Vice President
    Bell IT Services
    rob@bellit.net
  • 2.  RE: AP-605H - 6 GHz will not activate (8.12.0)
    Posted Jun 23, 2024 10:45 PM
    When you configure a new WLAN, you need to enable it for 6G
    configuration -> Networks -> show adv options ->under 801.11
  • 3.  RE: AP-605H - 6 GHz will not activate (8.12.0)
    Posted Jun 24, 2024 10:36 AM
    Items to verify:
    1. AP flex band configuration is set to allow 6 GHz.
    2. 6 GHz is enabled for the WLAN.
    3. WLAN is configured for WPA3, with or without transition mode.
    4. The DRT shows support for 6 GHz on the AP-605H in the regulatory domain used.
    Carson Hulcher, ACEX#110
