The APs will use the untagged VLAN as the "AP management" VLAN. You need to make sure that DHCP, DNS, and Default gateway are working on the untagged VLAN.
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: Sep 28, 2024 06:00 AM
Subject: AP-615 Issues
we have Aruba 6300M switch configure as Backbone switch with DHCP configure and Aruba 6000 Working like distribution switch and 2 Aruba AP-615 connected to Aruba 6000 switch we need to configure 2 SSID on the AP one for User with vlan 20 and one for Guest Vlan 50 when we configure AP port as trunk mode SSID network working but AP showing down on Aruba Central !!! , and also we facing issues with SSID stability Wi-Fi keep disconnected and reconnected automatically with the both of devices.
