Sorry, I received the information that Windows version 10.0.x is indeed what we know as Windows 11... my bad.
But from the output, it looks like the SSID is broadcasted on 6GHz. Not sure why the client does not connect. If you have other WiFi-6E clients to test with, that would make it more clear if the issue is in the client or in the AP/SSID...
Original Message:
Sent: Dec 14, 2023 07:59 AM
Subject: AP-615's ....seems to broadcast 6ghz band .....STRUGGLING to get 6ghz compatible to connect
Its Windows 11 ... not 10.
I am well aware that Windows 10 does not work with the 6Ghz band.
Original Message:
Sent: Dec 14, 2023 04:12 AM
The screenshot above suggests that you run Windows 10. I've not been successful to connect to 6GHz with Windows 10, and when I upgraded to Windows 11 it worked right away. You mentioned that your clients are Win 11, but the screenshot shows a 10.x version....
Do you have a modern mobile phone that supports 6GHz to test with? Using another device may help to find out if there is something with the AP or the client...
Original Message:
Sent: Dec 13, 2023 10:07 AM
The clients are Windows 11 (required) ..... a few of my devices have Intel 160MHz wifi cards in them with the latest drivers .... and another of my clients has a MediaTek 160MHz wifi card in it.
I have tinkered with the driver settings in my testing for each and had no luck.
The MediaTek one actually has a setting where you can choose to only show the 6 Ghz band broadcasts and as I expected it didnt list any SSID's when I set it to this.
Original Message:
Sent: Dec 13, 2023 10:00 AM
What client and driver version? Have you changed any default driver settings?
Josh
Original Message:
Sent: Dec 13, 2023 09:52 AM
Screenshots of the 4 AP's with the 6 band SSID ........ there are BSSID's ....
Original Message:
Sent: Dec 13, 2023 09:34 AM
"show ap bss-table", you for sure are seeing BSSIDs operating on 6 GHz?
Carson Hulcher, ACEX#110
Original Message:
Sent: Dec 13, 2023 09:08 AM
My environment is two 7205 controllers and 170 AP-615's. I am currently trying to get the 6ghz band to work.
For testing I have an AP group of 4 AP's , OS 8.11.2.0, and a new SSID using WPA3. Devices can connect but the max I am getting is 5ghz. They are Windows 11 and have compatible cards.
Does anybody have a similar environment with success .... or does anybody have any thoughts?
