  • 1.  AP-634 6GHz radio not enabled in Aruba Central
    Posted Sep 24, 2024 01:06 PM
    I have six AP-634 access points in Aruba Central and all of them show that the 6GHz radio is disabled even though the 6GHz radio is selected in their AP configuration.
    Also, on the external antenna settings for the AP-634, what should the antenna gain and polarization be set to for each radio?
  • 2.  RE: AP-634 6GHz radio not enabled in Aruba Central
    Posted Sep 24, 2024 01:49 PM
    What regulatory domain?
    The frequency coordination required for the AP-634 to operate the 6 GHz radio in regulatory domains where AFC is required, isn't currently available.
    Antenna settings should be set based on what antenna you have.
    Carson Hulcher, ACEX#110
  • 3.  RE: AP-634 6GHz radio not enabled in Aruba Central
    Posted Sep 24, 2024 02:17 PM
    The attached document may be helpful. We can only enable radios (and bands, channels) based on the local rules and the certs we have. We will continue to adjust and expand what bands, channels and power levels are supported on each AP model, and have a flexible mechanism to dynamically adjust that in the products (DRT file), but the number of countries where we can currently enable the 6GHz radio on an AP supporting detachable antennas is quite limited. Most countries simply do not allow it, or the rules are new or still being defined.
    /Onno Harms, Aruba Wireless Product Management
    Attachment(s)
  • 4.  RE: AP-634 6GHz radio not enabled in Aruba Central
    Posted Sep 24, 2024 03:25 PM
    Edited by wdubose Sep 24, 2024 03:27 PM
    So basically, Even without an external antenna attached, 6GHz is automatically disabled on AP-634 in US?
  • 5.  RE: AP-634 6GHz radio not enabled in Aruba Central
    Posted Sep 24, 2024 03:32 PM
    Right now, yes.
