  • 1.  AP-635
    Posted 10 days ago
    If I use both E0 and E1 to connect the AP-635 to the network, do I need to have both switch ports configured the same (same VLAN, etc.)?  Also, do I need to set up LAG on the switches for those 2 switch ports?
    Peter
  • 2.  RE: AP-635
    Posted 10 days ago
    Uplink configuration must be identical.
    LAG using LACP is an option, default operation is active/standby failover.
    https://arubanetworking.hpe.com/techdocs/aos/aos10/design/ap-ports/
    Carson Hulcher, ACEX#110
  • 3.  RE: AP-635
    Posted 10 days ago
    Thank you.  So if I connect both uplink ports (E0 and E1) to the network switches, they will automatically go to active/active or active/standby configuration?  No need to configure LAG on the switch side?  Seems that configuring LAG for every AP would be quite a task.
    Peter
  • 4.  RE: AP-635
    Posted 10 days ago
    Active/standby.  The only way for both ports to be active simultaneously is when LACP is used.
  • 5.  RE: AP-635
    Posted 2 days ago
    We have a few 635s (and 655s) configured using LACP.  Does the AP provide potentially higher throughput given this configuration?
  • 6.  RE: AP-635
    Posted 2 days ago
    Potentially yes, in practice you probably don't hit the throughput limit of a single interface.
