[AP-635]: 8.10.0.5, massive management frames on 2.4 GHz and 6 GHz
This thread has been viewed 32 times
  • 1.  [AP-635]: 8.10.0.5, massive management frames on 2.4 GHz and 6 GHz
    Posted Dec 01, 2022 02:46 AM
    Edited by MichaelM55 Dec 01, 2022 02:47 AM
    So, let´s look at one of our Aruba AP-635 access points. What cause those high rates of management frames and errors, concurrently on 2.4 and 6 GHz?
    • 5 GHz is ok
    • 2.4 Ghz is full of management frames, massive errors, except utilization is low
    • Let´s look at 6 GHz. There is no client connected, but management frames and error counters are at the same level as those on 5 GHz; at the same time.
  • 2.  RE: [AP-635]: 8.10.0.5, massive management frames on 2.4 GHz and 6 GHz
    Posted Dec 01, 2022 09:55 AM
    Because the numbers for 'Out' look the same on 2.4Ghz and 6G, I expect a bug in the WebUI. Please open a TAC case.
    71.5 million frames per second seems unrealistic high, can't imagine that the number is correct.
