AP 635 - Do we etherchannel?
This thread has been viewed 33 times
  • 1.  AP 635 - Do we etherchannel?
    Posted Feb 09, 2023 11:38 AM
    Hi all - with the 600 series APs we're looking to utilise both ethernet ports. Are there any thoughts about etherchannel connections etc?
  • 2.  RE: AP 635 - Do we etherchannel?
    Posted Feb 09, 2023 12:23 PM
    First, we don't use Etherchannel but rather create the LAG using LACP or you can utilize the active/standby functionality.
    In general the effort for provisioning the LAGs doesn't provide enough benefit to be worthwhile, and active/standby will meet the usual redundancy requirements while also not requiring a single logical switch.
    Carson Hulcher, ACEX#110
  • 3.  RE: AP 635 - Do we etherchannel?
    Posted Mar 02, 2023 12:15 PM
    No,
    There will be no performance impact for clients.
    (There is no need for LAG in any Aruba dual eth. AP's)
    Steinar
  • 4.  RE: AP 635 - Do we etherchannel?
    Posted Jul 10, 2024 03:45 AM
    Why would there be no benefit to the clients?  It would seem obvious that dispatching packets balanced across the two eth0/1 should improve throughput. Or is the default LACP not set up that way? How can we configure the AP's LACP to negotiate load balancing with the switch?  (The documentation I have been able to find on this is pretty obtuse.)
    Caveat: if the AP is tunneling client traffic back tot he controller, then LACP would see the tunnel as the one & only session, which would NOT be balanced across LAG member links. But if not tunneling ... ?
  • 5.  RE: AP 635 - Do we etherchannel?
    Posted Jul 10, 2024 10:35 AM
    I have numerus post on the topic in the forum, there is no proven experience at all
    (for aggregated benefit, as you suggest],
    Just plug in the two cables, and work with that :) [all other consideration set aside]
    Steinar
