I have numerus post on the topic in the forum, there is no proven experience at all
(for aggregated benefit, as you suggest],
Just plug in the two cables, and work with that :) [all other consideration set aside]
Steinar
Original Message:
Sent: Jul 09, 2024 01:31 PM
Subject: AP 635 - Do we etherchannel?
Why would there be no benefit to the clients? It would seem obvious that dispatching packets balanced across the two eth0/1 should improve throughput. Or is the default LACP not set up that way? How can we configure the AP's LACP to negotiate load balancing with the switch? (The documentation I have been able to find on this is pretty obtuse.)
Caveat: if the AP is tunneling client traffic back tot he controller, then LACP would see the tunnel as the one & only session, which would NOT be balanced across LAG member links. But if not tunneling ... ?
Original Message:
Sent: Mar 02, 2023 12:15 PM
No,
There will be no performance impact for clients.
(There is no need for LAG in any Aruba dual eth. AP's)
Steinar
Original Message:
Sent: Feb 09, 2023 11:37 AM
Hi all - with the 600 series APs we're looking to utilise both ethernet ports. Are there any thoughts about etherchannel connections etc?
