Again, roaming is a client decision, based on whatever proprietary algorithm the client vendor implemented. Nothing the AP can do about that.
Perhaps your client devices prioritize certain capabilities and metrics over signal strength.
Did the performance degrade when they moved to the AP-515? If not, what's the problem? As I said, if the client is connected on 5GHz, the AP-515 may very well be the better choice to connect to.
Sorry for misunderstanding the relative distances. But even 60 versus 25 feet, would just be 4dB or so. Obviously a lot more if you add three walls as you mention. What's the difference in signal strength reported by the client device?
/Onno Harms
Wireless Platforms Product Management
HPE Aruba Networking
Original Message:
Sent: May 27, 2025 08:25 AM
Subject: AP-635 inferior to AP-535/AP-515?
When I rebooted all the AP the AP635 was up way before the AP515, and all the clients were connected to the AP635, over time once the AP515 is up several devices end up moving even though the AP they move to is further away.
Original Message:
Sent: May 27, 2025 08:18 AM
The APs are 35 ft apart, so the 515 is 60+ ft away versus 25 feet away. Both are configured for 80Mhz bands according to the BSS tables. What I think is odd is that there are three devices below the AP635 10 feet or so, and all three are connected to the AP515 which would be 40+ feet away thru three walls.
Original Message:
Sent: May 27, 2025 12:04 AM
Well, if this is on 5GHz, both AP-515 and AP-635 are of the same Wi-Fi 6 generation (802.11ax), and the 5GHz radio on AP-515 is 4x4 versus 2x2 on AP-635. So if this client device is connected in the 5GHz band, it probably makes sense that it has a preference for the AP-515 radio. 35ft versus 25ft equates to a 1-2dB difference only (assuming everything else is identical, which it never is ;-), which is not significant. The value of a Wi-Fi 6E AP is in the addition of 6GHz support; other than that the PHY & MAC layers are the same.
What channel bandwidth are you using? AP-515 does support HE160 in 5GHz (rarely used in an enterprise campus network) while AP-635 is limited to HE80.
/Onno Harms
Original Message:
Sent: May 26, 2025 11:05 PM
I would agree if is was a single device, but it is multiple devices on different products. It seems that most devices would rather connect to the AP515 which is 35 feet further away than connect to the 635 which only 25 feet away. So it is either a defective AP635 (new device) or the 635 is fundamentally inferior to the AP515.
They both have the same version of firmware, What I see is if a device is connected to the 635 it's signal strength is obviously higher, but bit rate is lower. When the same device is connected to the 515, the signal strength is lower, but the bit rate is higher. Since they are running as a single network, the configs are exactly the same. Even though the bit rate is higher the actual performance is lower due to the wireless mesh.
That is on one of the laptops, the bitrate for the AP635 is 720 versus 1200 for the AP515 which is 60 feet away.
Original Message:
Sent: May 26, 2025 10:09 PM
I'm a bit confused by this message. In Wi-Fi it's ultimately the client device that decides which AP to connect to, so if they connect to a weaker AP, that says more about the device you're testing with than the APs. Also, it sounds like you've set up the AP-515 and AP-635 to establish a mesh link? How does that make one AP inferior to another?
/Onno Harms
Original Message:
Sent: May 25, 2025 08:27 AM
I was assuming the 635 had more capability than the 515. But what I have noticed is that clients attach to the 515 rather than the 635. Even when the 635 is closer. What makes it interesting is that the 515 backhauls to the 635 wirelessly. That is all the 515 traffic goes thru the 635 wirelessly! So what AP would be a better central communications conductor. It seems the 635 is truly inferior to the 500 series devices.
Original Message:
Sent: May 29, 2021 03:39 AM
so AP-635 has arrived lately: https://www.arubanetworks.com/products/wireless/access-points/indoor-access-points/630-series/
I must admit that I don´t like what I see:
1, Why did Aruba choose a glossy surface? This might blend and therefor bother everyone sitting around in certain lightning environments.
2. Shouldn´t be a "AP-635" the successor of a "AP-535"? Let´s compare AP-635 with AP-535 and AP-515: https://www.arubanetworks.com/products/wireless/access-points/compare/#132904,150581,298786
- AP-635 supports 2x2:2 for each band, only. As Aruba wants it to run in a kind of limited mode with 802.3af, this might be ok. But shouldn´t therefore be a kind of smaller ~AP-615?
- AP-635 support SU-MIMO, only? No DL-MU-MIMO, no UL-MU-MIMO? Even 802.11ac (Wave 2) supports DL-MU-MIMO. So, is this a typo?
- Regarding "Max number of Resource Units (OFDMA)": AP-635 supports (up to) 8 RUs, AP-535 supports (up to) 37 RUs, AP-515 supports (up to) 16 RUs.
What is one of the biggest features of 802.11ax one is us telling about for years? => Yes, it´s OFDMA. Now with AP-635 being a 3rd generation 802.11ax access point, it supports less RUs than the 2nd generation (AP-535/AP-555) and even less than the first generation* (AP-515)?
(* I myself call AP-515 a first generation/Wave 1 802.11ax access points as its chipset is not capable of UL-MU-MIMO.)
If I remember correctly, AP-515 uses a Broadcom (BCM43694?) chipset, AP-535/AP-555 uses a Qualcomm (Networking Pro 1200) chipset for wireless. As Qualcomm´s current Wi-Fi 6E chipsets (Networking Pro 610, Networking Pro 810, Networking Pro 1210, Networking Pro 1610) support up to 37 RUs, may I ask which chipset vendor and which chipset is being used for the AP-635 access point? (Hopefully not Mediatek MT79xx which supports 2x2:2 for 2.4 GHz, 5 GHz and 6 GHz radio, aswell)
