I've wasted a good two days trying to get this working...
I presently have an AP-635 (#1) acting as a mesh portal to an IAP-305 (mesh point) providing a downlink to a remote switch. This has been working reliably for some time.
I am now attempting to add an additional AP-635 (#2) as a second mesh point downlink:
Is this possible? Can a Mesh Portal provide access to two Mesh Points? I cannot get the second AP-635 to connect as a Mesh Point.
UPDATE:
I just noticed the Mesh Name is different (Dashboard -> Mesh Devices) for AP-635 #2! Why is it not using the same mesh SSID as the other two APs?
Wired Network config:
AP-635 #2 config:
Commentary:
This same configuration is working fine with the IAP-305. The only difference is the IAP-305 has only one interface (ETH0).
As to the AP-635, I've tried both ETH0/ETH1 Downlink/Uplink and Uplink/Downlink. In either configuration, I can connect the Uplink interface via cable to my network and the AP-635 happily joins as a Mesh Portal (as expected). However, if I connect to the Downlink (only) to a remote PoE+ switch, the AP-635 blinks the power LED forever and never joins as a Mesh Point. I'm at a loss.
I have also tried ETH0/ETH1 as Downlink/Downlink. In that case, I get nothing and end up doing a factory reset to regain access to the AP.
I note "mesh auto eth0 bridging" here is "no", but of course I'm connected to the Uplink (ETH1) in order to run this command:
3/8/2024 22:05:19 PM Target: AP-635-US-2 Command: show swarm state
AP Swarm State :swarm_config_sync_complete
mesh auto eth0 bridging :no
Config in flash :no
factory SSID in flash :no
extended-ssid configured :no
extended-ssid active :no
advanced-zone configured :no
Factory default status :no
Source of system time :NTP server
Config load cnt :1
VC Channel index :3
IDS Client Gateway Detect :yes
Config Init success cnt for heartbeat :0
Config Init success cnt for register :1
Config Init skipping cnt for heartbeat :0
Config Init skipping cnt for register :0
Config Init last success reason :heartbeat
Config Init last success time :2024-03-07 16:36:39
Radio down state :0x0 / 0x0 / 0x0
Thermal Protect state :None
6GHz disabled in MFG :FALSE
6GHz AFC required :FALSE
6GHz FILS status :disabled
6GHz FILS auto selection :enabled
All devices are running Instant v.8.12.0.0. Any assistance is appreciated! Thanks!
