Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
Jump to Best Answer
This thread has been viewed 62 times
  • 1.  Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 19, 2022 08:54 AM
    The AP 6 Ghz is not started, only 2.4 & 5 is working, with green led lights.
    The Ap is in a controller/ Conductor env.
    All settings is by the book, as shown in document online.
    Ie: Configuring 6 GHz Radio Profile (arubanetworks.com)
    Steinar Grande
  • 2.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 12:45 AM
    What's the DRT version, and what's the configured country of operation?
    An amber radio LED means the radio is in scanning mode, which happens either when configured as such, or when the DRT file indicates that the the radio has not yet been certified for operation in the target country.
    Onno Harms
  • 3.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 03:28 AM
    The DTR is 8.10; which is the required one for AP-655.
    The Regulatory Domain is the correct country of operation, with valid 6Ghz channels
    (Changing it, makes no different)
    Steinar Grande
  • 4.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 09:07 AM
    This is severely disturbing:
    (ArubaMM) [mynode] #show ap allowed-channels country-code no ap-type ap-655 | include 6GHz
    6GHz (LP indoor) None
    6GHz 40MHz (LP indoor) None
    6GHz 80MHz (LP indoor) None
    6GHz 160MHz (LP indoor) None
    Other Country :!!!!
    (ArubaMM) [mynode] #show ap allowed-channels country-code se ap-type ap-655 | include 6GHz
    6GHz (LP indoor) 1 5 9 13 17 21 25 29 33 37 41 45 49 53 57 61 65 69 73 77 81 85 89 93
    6GHz 40MHz (LP indoor) 1-5 9-13 17-21 25-29 33-37 41-45 49-53 57-61 65-69 73-77 81-85 89-93
    6GHz 80MHz (LP indoor) 1-13 17-29 33-45 49-61 65-77 81-93
    6GHz 160MHz (LP indoor) 1-29 33-61 65-93
    (ArubaMM) [mynode] #show ap allowed-channels country-code dk ap-type ap-655 | include 6GHz
    (ArubaMM01v-osl) [mynode] #show ap allowed-channels country-code us ap-type ap-655 | include 6GHz
    6GHz (LP indoor) 1 5 9 13 17 21 25 29 33 37 41 45 49 53 57 61 65 69 73 77 81 85 89 93 97 101 105 109 113 117 121 125 129 133 137 141 145 149 153 157 161 165 169 173 177 181 185 189 193 197 201 205 209 213 217 221 225 229
    6GHz 40MHz (LP indoor) 1-5 9-13 17-21 25-29 33-37 41-45 49-53 57-61 65-69 73-77 81-85 89-93 97-101 105-109 113-117 121-125 129-133 137-141 145-149 153-157 161-165 169-173 177-181 185-189 193-197 201-205 209-213 217-221 225-229
    6GHz 80MHz (LP indoor) 1-13 17-29 33-45 49-61 65-77 81-93 97-109 113-125 129-141 145-157 161-173 177-189 193-205 209-221
    6GHz 160MHz (LP indoor) 1-29 33-61 65-93 97-125 129-157 161-189 193-221
    Steinar Grande
  • 5.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 10:04 AM
    Please make sure that you are on DRT 1.0_83381 or up for 2.4GHz, 5GHz and 6GHz bands. For Instant mode check under Maintenance -> Regulatory in the WebUI.
    8.10 is the firmware version, DRT comes at a specific version with each firmware but also can be upgrade independently. So either upgrade to the very latest firmware (and hope that DRT version is new enough), or manually upgrade to the most recent DRT file. Understand that this may look cumbersome, but that is because some countries take more time to open up the 6GHz band and Aruba needs to be compliant to local regulations in each of the countries.
  • 6.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 01:50 PM
    We release a new DRT file roughly every two weeks.
    The 6GHz band is opened up by individual countries in the EU gradually, and we can only enable the band once it is legally allowed to do so.
    Support for 6GHz in Norway was introduced in version 83381.
    If your version is older, please upgrade. If it's newer, we're dealing with a bug. Please let us know.
    Onno Harms
  • 7.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 02:14 PM
    I am on FW ArubaOS_MM_8.10.0.0_83812 & ArubaOS_72xx_8.10.0.0_83812, which shall cover it.
    The regulatory authorities opende the 6Ghz in Juli 1. 2021
    Steinar Grande
  • 8.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 03:01 PM
    Steinar,
    That AOS release includes DRT version 83672, so you're right in that 6GHz should be supported on AP-655 in that release.
    Let me find out why that's not reflected in that version, if it's any different in the latest one, and whether a fix is needed in the next DRT release.
    Onno Harms
