Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
This thread has been viewed 87 times
  • 1.  Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 19, 2022 08:54 AM
    The AP 6 Ghz is not started, only 2.4 & 5 is working, with green led lights.
    The Ap is in a controller/ Conductor env.
    All settings is by the book, as shown in document online.
    Ie: Configuring 6 GHz Radio Profile (arubanetworks.com)
    Steinar Grande
  • 2.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 12:45 AM
    What's the DRT version, and what's the configured country of operation?
    An amber radio LED means the radio is in scanning mode, which happens either when configured as such, or when the DRT file indicates that the the radio has not yet been certified for operation in the target country.
    Onno Harms
  • 3.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 03:28 AM
    Edited by Steinar Grande May 20, 2022 03:28 AM
    The DTR is 8.10; which is the required one for AP-655.
    The Regulatory Domain is the correct country of operation, with valid 6Ghz channels
    (Changing it, makes no different)
    Steinar Grande
  • 4.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 09:07 AM
    This is severely disturbing:
    (ArubaMM) [mynode] #show ap allowed-channels country-code no ap-type ap-655 | include 6GHz
    6GHz (LP indoor) None
    6GHz 40MHz (LP indoor) None
    6GHz 80MHz (LP indoor) None
    6GHz 160MHz (LP indoor) None
    Other Country :!!!!
    (ArubaMM) [mynode] #show ap allowed-channels country-code se ap-type ap-655 | include 6GHz
    6GHz (LP indoor) 1 5 9 13 17 21 25 29 33 37 41 45 49 53 57 61 65 69 73 77 81 85 89 93
    6GHz 40MHz (LP indoor) 1-5 9-13 17-21 25-29 33-37 41-45 49-53 57-61 65-69 73-77 81-85 89-93
    6GHz 80MHz (LP indoor) 1-13 17-29 33-45 49-61 65-77 81-93
    6GHz 160MHz (LP indoor) 1-29 33-61 65-93
    (ArubaMM) [mynode] #show ap allowed-channels country-code dk ap-type ap-655 | include 6GHz
    (ArubaMM01v-osl) [mynode] #show ap allowed-channels country-code us ap-type ap-655 | include 6GHz
    6GHz (LP indoor) 1 5 9 13 17 21 25 29 33 37 41 45 49 53 57 61 65 69 73 77 81 85 89 93 97 101 105 109 113 117 121 125 129 133 137 141 145 149 153 157 161 165 169 173 177 181 185 189 193 197 201 205 209 213 217 221 225 229
    6GHz 40MHz (LP indoor) 1-5 9-13 17-21 25-29 33-37 41-45 49-53 57-61 65-69 73-77 81-85 89-93 97-101 105-109 113-117 121-125 129-133 137-141 145-149 153-157 161-165 169-173 177-181 185-189 193-197 201-205 209-213 217-221 225-229
    6GHz 80MHz (LP indoor) 1-13 17-29 33-45 49-61 65-77 81-93 97-109 113-125 129-141 145-157 161-173 177-189 193-205 209-221
    6GHz 160MHz (LP indoor) 1-29 33-61 65-93 97-125 129-157 161-189 193-221
    Steinar Grande
  • 5.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 10:04 AM
    Please make sure that you are on DRT 1.0_83381 or up for 2.4GHz, 5GHz and 6GHz bands. For Instant mode check under Maintenance -> Regulatory in the WebUI.
    8.10 is the firmware version, DRT comes at a specific version with each firmware but also can be upgrade independently. So either upgrade to the very latest firmware (and hope that DRT version is new enough), or manually upgrade to the most recent DRT file. Understand that this may look cumbersome, but that is because some countries take more time to open up the 6GHz band and Aruba needs to be compliant to local regulations in each of the countries.
  • 6.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 01:50 PM
    We release a new DRT file roughly every two weeks.
    The 6GHz band is opened up by individual countries in the EU gradually, and we can only enable the band once it is legally allowed to do so.
    Support for 6GHz in Norway was introduced in version 83381.
    If your version is older, please upgrade. If it's newer, we're dealing with a bug. Please let us know.
    Onno Harms
  • 7.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 02:14 PM
    I am on FW ArubaOS_MM_8.10.0.0_83812 & ArubaOS_72xx_8.10.0.0_83812, which shall cover it.
    The regulatory authorities opende the 6Ghz in Juli 1. 2021
    Steinar Grande
  • 8.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 03:01 PM
    Steinar,
    That AOS release includes DRT version 83672, so you're right in that 6GHz should be supported on AP-655 in that release.
    Let me find out why that's not reflected in that version, if it's any different in the latest one, and whether a fix is needed in the next DRT release.
    Onno Harms
  • 9.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 20, 2022 04:28 PM
    The team seems to have identified the issue, and will fix it in the next DRT release (whatever the version number after 84001 will be).
    Onno Harms
  • 10.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 21, 2022 04:56 AM
    Can it be a workaround?, can the no abbreviation be replaced with eg. se ??
    Changing the regulatory domain in ap-group has no effect.
    Hence the fact I have 100 AP-655 stockpiled to bee deployed next week !
    Steinar Grande
  • 11.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 22, 2022 08:48 PM
    Changing the country code to SE could be a workaround I suppose. Based on the info above it seems that in that case the 6GHz channels are indeed enabled. But I'm confused by your comment that changing the regulatory domain (to SE I assume) has no effect.
    Note that the new DRT is expected to be available by the end of this week or early next week.
    Onno Harms
  • 12.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 23, 2022 12:52 AM
    This has no effect:
    I assume this takes precedence ?:
    Please advice on change Country
    Steinar Grande
  • 13.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 23, 2022 01:13 PM
    I'll need someone else to chime in on that.
    Are you working with Aruba support?
    Onno Harms
  • 14.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 24, 2022 03:43 AM
    Yes, TAC case#: 5364589431
    Steinar Grande
  • 15.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 25, 2022 08:31 AM
    There was a new bulletin release about this. See Bulletin ARUBA-FB-AP2205-2
    This is due to new hardware used and affects AOS 10.
    Here is the solution.
    When using any of the affected AP platforms, upgrade to ArubaOS or Instant 8.10.0.1 or later ASAP. Do not downgrade to 8.10.0.0.
    Bruce Osborne ACCP ACMP
    Liberty University
    The views expressed here are my personal views and not those of my employer
  • 16.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 25, 2022 09:12 AM
    NO, that is unrelated to this issue, read the thread.
    Steinar Grande
  • 17.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 25, 2022 08:22 PM
    Definitely unrelated, and not applicable to any AP-655s already in the field. The issue in the field bulletin applies to AP-655 hardware with a new PHY revision that is not yet currently shipping.
    Steinar: when you change the country of operation to SE, enable 6GHz and define a VAP in that band (using OWE or WPA3 security), the 6GHz radio LED remains orange?
    Onno Harms
  • 18.  RE: Ap-655 6 GHz Led Orange, and no 6 Ghz SSID
    Posted May 25, 2022 11:16 PM
    Edited by Steinar Grande May 25, 2022 11:20 PM
    Yes, (to last part, still Orange, and with 8.10.0.1_84079.)
    Steinar Grande
