  • 1.  AP-7250 defaults won't reset
    Posted Feb 05, 2009 10:19 AM
    I have just purchased a used 3CRWE725075 WAP-7250 and following 3com's knowledge base ID 3KB12341 for resetting factory defaults I can't get the reset to take.. This procedure seems very straight forward. Is there something else I can do or that I may be overlooking? Other than not being able to reset the unit it seems to be working perfectly.
    Thanks!!
  • 2.  RE: AP-7250 defaults won't reset
    Posted Feb 05, 2009 08:03 PM
    Yea, I know I'm replying to my own post but I have the solution.. Hope this helps someone else.
    The solution I found involved using the factory reset for a completely different group of 3com AP's.
    What I did was to remove the ethernet connection and with the unit powered up I pressed the reset button for 30 seconds. After that the unit reset to factory defaults but this included DHCP enabled. I do have DHPC running at home and 3com's wireless device manager was able to see the new IP under properties. From there I used the browser to connect to the AP the user name is "admin" and the password is "left blank" (It says this right on the login page). From there it's a snap. I still can't get the wireless device manager to configure the device just to get the properties but I can live with that.
    Hope this helps!!
  • 3.  RE: AP-7250 defaults won't reset
    Posted Apr 06, 2011 10:48 AM
    Is there a link for the most recent firmware? Thanks!
  • 4.  RE: AP-7250 defaults won't reset
    Posted Feb 01, 2012 11:09 PM
    It looks like you'll needs a software support contact.
