  • 1.  AP and controller images
    Posted Feb 25, 2013 08:55 AM
    I have a requirement to place an image on an AP (from factory default) without the AP having access to a controller. I understand that there are files - mips.ari, mips32.ari, mips64.ari. What the usage for these files and will one of them be able to do the job.
    Thanks.
  • 2.  RE: AP and controller images
    Posted Feb 26, 2013 05:21 AM
    Words of warning!
    Following this procedure if done incorrectly might brick the AP!!
    Do not attempt to upgrade the AP boot code unless told to by TAC - otherwise more than likely you will be phoning to RMA the AP.
    Only upgrade the ap 'os' image.
    This is for an AP-105 (with 8MB flash) (command syntax differs slightly with newer boot code)
    Note: value for bootfile is used as the image name.
    APBoot 1.0.9.12 (build 22797)
    Built: 2009-11-04 at 15:53:54
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM:  128 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  0029 00002   01 10000000 00000000 00000000 00000000
           01  00  168c  0029 00002   01 10010000 00000000 00000000 00000000
    Net:   eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot:  0
    apboot> printenv
    bootdelay=2
    baudrate=9600
    autoload=n
    boardname=Talisker
    servername=aruba-master
    bootcmd=boot ap
    autostart=yes
    bootfile=mips32.ari
    ethaddr=00:24:6c:c2:eb:e2
    stdin=serial
    stdout=serial
    stderr=serial
    ethact=eth0
    Environment size: 209/65532 bytes
    apboot> setenv serverip 192.168.254.9
    apboot> help upgrade
    upgrade boot <file>
       - upgrade the APBoot image from <file>
    upgrade os <file>
       - upgrade the OS image from <file>
    apboot> upgrade os mips32.ari
    eth0 up: 1 Gb/s full duplex
    DHCP broadcast 1
    DHCP IP address: 192.168.254.45
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 192.168.254.254
    DHCP DNS server: 192.168.254.254
    DHCP DNS domain:
    Controller address: 192.168.254.9
    Using eth0 device
    TFTP from server 192.168.254.9; our IP address is 192.168.254.45
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: #################################################################
    done
    Bytes transferred = 5659932 (565d1c hex)
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Erasing flash... .......................................................................................done
    Erased 87 sectors
    Copying to flash...
    Writing ......................................................................................done
    Verifying flash... 5659932 bytes were the same
    Upgrade successful.
    apboot>
  • 3.  RE: AP and controller images
    Posted Feb 26, 2013 11:30 AM
    That's brilliant, Giles, thanks. What are the other two files used for mips and mips64?.
  • 4.  RE: AP and controller images
    Posted Feb 27, 2013 04:26 AM
    mip64.ari is ap-12x
    mips.ari is for ap-6x etc
    just use the bootfile specified in the printenv of the AP you are using.
  • 5.  RE: AP and controller images
    Posted Apr 04, 2013 06:42 PM
    Thanks Giles. I was struggling to convert some IAP105s to AP105s (I only have an Aruba 200 running 5.0.4.11), when I came across this post. Worked a treat.
  • 6.  RE: AP and controller images
    Posted Jul 24, 2018 04:29 AM
    Hi everyone,
    Ap is not reach the controller and it doesn't upgrade the os. I want to upgrade with the tfpt server from my computer, so I need this file which is name is "mips32.ari". Where can I download it?
    I'm waiting your help, thank you.
    Regards
  • 7.  RE: AP and controller images
    Posted Jul 24, 2018 06:48 AM
    This is an old thread.
    Access points cannot operate without a controller, so obtaining the image and upgrading them manually will not fix anything.  Fix connectivity between the access point and the controller and then everything should work.  What are you using for the access points to discover the controller?
  • 8.  RE: AP and controller images
    Posted Jul 24, 2018 10:35 AM
    I couldn't explain exactly. We configure the Ap in the office and after we setup it on the location.
    Sometimes we can make a mistake. If we don't configure correctly, we should configure remotely ofcourse. and if we have zyxel v2 modem on the location, Ap is cannot upgrade from the controller. So we must take it back
    and must configure in the office again.
    That's why I'm searching that file. If I have that file in my computer, I can upgrade with tftp server. I don't know it's clearly or not.
    Regards.
