ap cannot give ssid after reset factory
  • 1.  ap cannot give ssid after reset factory
    Posted Dec 02, 2018 01:48 AM
    Hi Guys,
    i have ap 225 aruba. i was reset to factory default the ap
    and i want to console ap via web gui.
    but when i give static ip, the ap always restart automatic. i dont know whats problem ?
    and ap can't give ssid instant and the led power always blinking
    this is log when i not yet give the ip address
    Domain Name: arubanetworks.com
    No panic info available
    Ethernet port 1 mode: active-standby
    ADDRCONF(NETDEV_UP): eth0: link is not ready
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    bonding: bond0: enslaving eth0 as a backup interface with a down link.
    ADDRCONF(NETDEV_UP): eth1: link is not ready
    bonding: bond0: enslaving eth1 as a backup interface with a down link.
    AP xml model 66, num_radios 2 (jiffies 3272)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 16
    radio 1: band 0 ant 0 max_ssid 16
    ethernet_device_event: dev eth0 is up
    ASAP Slowpath initialized
    Starting watchdog process...
    Getting an IP address...
    PHY: eth0 (mdio@ffe24000:00) - Link is Up - 10/Half
    bonding: bond0: link status definitely up for interface eth0.
    bonding: bond0: making interface eth0 the new active one.
    bonding: bond0: first active interface up!
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    Kevin
  • 2.  RE: ap cannot give ssid after reset factory
    Posted Dec 02, 2018 03:04 AM
    This is the end of your console output?
    Its seems that your Ethernet port / or cable might be on 10/half ?
    Please share with us the all console output.
  • 3.  RE: ap cannot give ssid after reset factory
    Posted Dec 04, 2018 03:58 AM
    problem solved.
