Hi Colin,
thank you for the reply. Yes, I know the things you have written and I think I have them configured properly. However I attach the "show ap config", so you can see my configuration and give me some suggestions.
I use the 2.4GHz radio of my AP93.
If I check the current EIRP I see this:
show ap debug driver-log ap-name "AP93_F5-TC2_223" | include EIRP
26 0.416996 wifi0: EIRP (Config: 15.0dBm, Set: 15.0dBm, AP Max: 20.0dBm, Reg Max: 19dBm), Conducted Power Set: 13.0dBm, Gain: 2.0dBm
59 1.070018 wifi0: EIRP (Config: 15.0dBm, Set: 15.0dBm, AP Max: 20.0dBm, Reg Max: 19dBm), Conducted Power Set: 13.0dBm, Gain: 2.0dBm
Massimo
