  • 1.  AP do not have signal on local controller
    Posted Nov 29, 2018 09:34 PM
    Hi guys,
    We have two controllers here, their relationship is master-local . When AP belongs to master controller ,it works normally and I can see the SSID from AP. But When AP belongs to local controller , I can't see the SSID
    Here is our conf:
    AP use DHCP get IP from the core switch.
    Core switch has a AP dhcp pool :
    ip dhcp pool AC
    network 10.80.99.0 255.255.255.0
    default-router 10.80.99.254
    dns-server 10.80.99.231 10.80.99.232
    option 43 ip 10.80.99.231
    PS:
    10.80.99.231 is master controller's IP
    10.80.99.232 is local controller's IP
    Unnormally situation: I found AP on local controller
    Any body had any thought?
  • 2.  RE: AP do not have signal on local controller
    Posted Nov 29, 2018 09:44 PM
    The local controller needs to have user VLANs defined directly on the controller.
  • 3.  RE: AP do not have signal on local controller
    Posted Nov 29, 2018 10:12 PM
    When I add back the vlan , It works,thank you so much....
