  • 1.  AP Firmware VELA vs Gemini
    Posted Jun 14, 2023 07:32 AM
    I'm in the task of upgrading a few of AP 207 and I'm a little confused on which firmware should I use.
    I see that some of the AP have the "VELA" and others "GEMINI" which one should I use ?
    I would use, if possible, the same version, either one is better, to standardize all the firmware versions
    thanks
  • 2.  RE: AP Firmware VELA vs Gemini
    Posted Jun 14, 2023 07:07 PM
    different AP models have different class of firmware which are indicated by the names like VELA, GEMINI, etc
    AP-207 uses VELA .
    Gemini is used for AP-500 and AP-500H series
    you can't use Gemini firmware on AP-207, it fact when you try, it will fail and will lwet you know that you are usng an incorrect class of firmware.
