You're looking to try to do the following:
Go to AP/Device list
Above the list is a 'modify devices' link -> click on that to get checkboxes next to the device names
Select devices you're trying to focus on
Then below the list table, choose the 'run report' option
This will take you into the report definition wizard where you can create a report definition for that device
In this case, client session report -> with include details about every session and every client toggled
Start and end time is relative to the time frame of the reported event. For example: Monday 9am - Monday 10am (this would give a report for clients that were on the selected APs between 9am and 10am on Monday.
I suggest using the 'add and run' for the report in case you need to widen the scope of the report period.
Note: the reporting period is restricted to the amount of data that you retain in AMP, double check your historical data retention values on AMP Setup -> General tab. For clients, the key data points are client association (default 2 weeks) and inactive client (default 2 months).
