  • 1.  AP is not booting up properly
    Posted May 06, 2018 05:28 PM
    Error:
    My AP is powering up but in the boot proccess I get the following error message and it doesn't do teh boot process correctly
    Could anyone help me with the below error message. Wht does that mean ?
    UBI error: ubi_read_volume_table: the layout volume was not found
    UBI error: ubi_init: cannot attach mtd3
    UBI error: ubi_init: UBI error: cannot initialize UBI, error -22
    Volume aos0 not found!
    Hit <Enter> to stop autoboot: 0
    Booting OS partition 0
    Checking image @ 0x0
    Invalid image format version: 0x0
    Checking image @ 0x2000000
    Volume aos1 not found!
    data abort
    AP- 300 series and only the Power LED is solid green
    Tank u in advance
    Sandz
  • 2.  RE: AP is not booting up properly
    Posted May 06, 2018 07:15 PM
    Try rebooting the AP after a factory reset.  It almost seems that you did a "reset" at the apboot menu and didn't reboot.
  • 3.  RE: AP is not booting up properly
    Posted May 07, 2018 01:10 AM
    I tried it already by giving the command factory_reset and then boot. Got the same error message
    Thank you
    Sandz
  • 4.  RE: AP is not booting up properly
    Posted May 07, 2018 06:24 AM
    What is the history of this access point?
  • 5.  RE: AP is not booting up properly
    Posted May 07, 2018 06:26 AM
    This is a new AP. Did a factory reset and tried to boot and got error messages.
    Sandz
  • 6.  RE: AP is not booting up properly
    Posted May 07, 2018 07:07 AM
    Please contact TAC so that they can Diagnose/RMA it.  You can contact them here:  http://www.arubanetworks.com/support-services/contact-support/
  • 7.  RE: AP is not booting up properly
    Posted May 07, 2018 07:14 AM
    Tank u
    Sandz
  • 8.  RE: AP is not booting up properly
    Posted Jul 27, 2022 02:45 AM
    I encounter this issue just now with AP-207
    Here how I fix
    1. erase first by pressing and hold hole at the bottom for 5s while plugging ethernet poe
    2. follow this and set static ip and upload using latest firmware
    https://acmxguy.wordpress.com/2020/05/06/aruba-iap-ap-boot-image-upgrade/
