AP manual provision issue
  • 1.  AP manual provision issue
    Posted Jul 17, 2023 12:17 AM
    Dears,
    i have an issue while i try to manually give ap ip and controller ip by console. the AP doesn't join the controller except if i configure the DHCP on the switch.
    Anyone face the same issue???
  • 2.  RE: AP manual provision issue
    Posted Jul 17, 2023 07:53 AM
    Is that for Aruba Instant AP? Aruba Controller based AP? Or other brand/type AP and controllers?
    For both Instant and Controller based APs it's strongly recommended to use DHCP to reduce configuration and errors, but either should work with static IP addresses.
    If it doesn't, and you can't find yourself what the issue is via console/controller/ap logging or packet captures, and you really can't use DHCP, it may be best to work with your Aruba Partner or Aruba Support to find out the issue.
