In an IAP cluster, once an AP is elected to be the Conductor, all of the other Access Points act as Members. If the Conductor AP goes down, re-election occurs, and a random Access Point is chosen as the new Conductor.
The criteria for choosing a Conductor can be found in the link below: https://www.arubanetworks.com/techdocs/Instant_83_WebHelp/Content/Instant_UG/CustomizeIAPParams/Master_Election_Protocol.htm
I don't see a way to configure a specific IAP to be the next conductor.
The "Preferred Conductor" setting can be used to elect a specific IAP as a Conductor. However, enabling it on more than one AP in a cluster is not recommended.
If you are looking for a way to ensure access to the Conductor IAP at all times, I would recommend setting up a Virtual Controller IP address.
Original Message:
Sent: Oct 11, 2023 05:35 AM
Subject: AP master and slave
Hi guys,
i have a problem with AP515. I have installed n° 60 APs.
How to set up an access point in master mode is clear but I would like one of the remaining ap to be slave. How do I configure an ap in slave mode? For example ip 10.40.200.11 master and 10.40.200.12 slave
thank you 1000
