Hi All,
I hope you are all well.
My question has been asked before, but I would like to know if there has been any update on this with any new versions of Aruba code.
My client would like to know if it is possible to disbale Aruba access points to save power. Is this possible with either Controller, AMP or Clearpass as they have the above three products. I see this has been asked before in the following:
http://community.arubanetworks.com/t5/Wireless-Access/Schedule-Aruba-AP-auto-power-shut-down/td-p/192775
This would need to be done on a schdule, so disabling should be like at 12am and then they should be re-enabled at 6am.
I advised them about potentially creating a script on their nagios monitoring tool that would log in to the controller and disable/re-enable the AP's, but they had dismissed this option.
If you have any advise or guidance on this that would be great.
