  • 1.  AP103 and Plenum Rating
    Posted Apr 11, 2014 03:42 AM
    Hi All
    What can i do and cannot do when an AP is not Plenum Rated?
    Can i still install it in the ceiling? is it just that i cannot place it between the false ceiling and hard ceiling?
    Harry
  • 2.  RE: AP103 and Plenum Rating
    Posted Apr 11, 2014 07:43 AM
    You can't install it in a plenum space. You'd want to check with local building code. Not all drop ceilings require plenum.
  • 3.  RE: AP103 and Plenum Rating
    Posted Jun 02, 2015 03:34 PM
    Resurrecting older thread here. I understand the 103 isn't rated for plenum, but I guess I'm not entirely clear what that entails. Would this disqualify it from being used in a residential attic? For example, mounted to rafters?
  • 4.  RE: AP103 and Plenum Rating
    Posted Jun 03, 2015 04:57 AM
    Clayman,
    Is there somewhere that you saw the Ap-103 is not rated for plenum?
  • 5.  RE: AP103 and Plenum Rating
    Posted Jun 03, 2015 11:14 AM
    Colin, yes. In the AP product line matrix it shows that the 103's are not plenum rated.
  • 6.  RE: AP103 and Plenum Rating
    Posted Jun 03, 2015 01:11 PM
    Please point me to the URL so that I can forward it to product marketing.
  • 7.  RE: AP103 and Plenum Rating
    Posted Jun 03, 2015 03:41 PM
  • 8.  RE: AP103 and Plenum Rating
    Posted Jun 03, 2015 07:43 PM
    It has to be double-checked because the datasheet says it is plenum rated.  http://www.arubanetworks.com/assets/ds/DS_AP103Series.pdf
  • 9.  RE: AP103 and Plenum Rating
    Posted Jun 03, 2015 08:17 PM
    It is plenum rated.  The AP Matrix needs to be fixed.  Thanks for pointing that out.
