We have WIFI project & Survey showed that we need some APs to be wall mounted
we want to use AP-103 to save cost & because areas are low density ... but found that inside AP103 datasheet it is written that " Built-in antennas are optimized for horizontal ceiling
mounted orientation of the AP."
Does this mean that AP103 is not good for wall mount & using AP-103H is a must ?
