  • 1.  AP103H in RAP mode
    Posted Oct 06, 2015 06:26 AM
    Customer is evaluating a large-scale (~180 remote sites) deployment of Remote Access Points. Central controller(s) with local access points and one AP per remote site. We cannot use the dedicated RAP models since there are no local regulatory versions; instead we plan to use IAP103 or AP103H. Question: if we use AP103H in remote AP mode - will it be possible to make use of extra LAN ports and connect wired devices (e.g. PCs, IP Phones, etc.) to central branch via the IPSces VPN?
    Yuly
  • 2.  RE: AP103H in RAP mode
    Posted Oct 06, 2015 08:39 AM
    from the AP 103 H datasheet - RAP mode is supported. So you should be able to use the ports ( Eth1 &  2) as extension over IPSec.
