AP105 in warehouse deployment
  • 1.  AP105 in warehouse deployment
    Posted Mar 27, 2012 02:19 PM
    30 foot ceilings, warehouse environment, laptops and RF guns will be connecting.  AP's will be ceiling mounted.  Will AP 105's internal antenna be enough for this?  Or should I go with AP 104 with external antennas?
  • 2.  RE: AP105 in warehouse deployment
    Posted Mar 27, 2012 02:38 PM
    I believe the AP-105 internal antennas should work fine especially with the 30' ceilings.
  • 3.  RE: AP105 in warehouse deployment
    Posted Mar 27, 2012 04:04 PM
    +1 on the AP105s.
  • 4.  RE: AP105 in warehouse deployment
    Posted Mar 27, 2012 03:35 PM
    Warehouse environments can be tricky, particularly depending on what type of inventory is being held. Things like cloth, liquids, or heavy metal objects are very unforgiving to RF. This is made worse if inventory racks reach all the way to the ceiling. I've done surveys for warehouse environments where omnidirectional antennae work great; and others where I needed to use directional antennae and shoot them straight down the aisles in order to provide the best coverage.
    I hope this helps. Let us know how it works out!
    - Jay
  • 5.  RE: AP105 in warehouse deployment
    Posted Mar 27, 2012 04:10 PM
    Ultimately it depends on the inventory, placement, and row lengths...but I did a recent warehouse deployment with AP-105s ceiling mounted.  The warehouse was 850,000 square feet with 50 foot ceilings.  The AP-105s are performing great in this particular environment.
  • 6.  RE: AP105 in warehouse deployment
    Posted Apr 16, 2012 06:50 PM
    Hi all, is there a known (approx) rule of thumb regarding the number of APs per area? Just to start with a number and then work from there.
    The warehouse will have 30 ft racks and one would expect them to be loaded to the top
    This project is in the very beginning, the warehouse is not even built yet by my customer needs to budget something close to the final figure
  • 7.  RE: AP105 in warehouse deployment
    Posted Apr 16, 2012 11:41 PM
  • 8.  RE: AP105 in warehouse deployment
    Posted Apr 17, 2012 10:43 AM
    thanks Colin, I´ve seen it already, I think it´s very helpful.
  • 9.  RE: AP105 in warehouse deployment
    Posted Apr 17, 2012 09:32 AM
    ?? Warehouse is complete
  • 10.  RE: AP105 in warehouse deployment
    Posted Apr 17, 2012 10:44 AM
    the warehouse has not been built yet
  • 11.  RE: AP105 in warehouse deployment
    Posted Apr 17, 2012 02:23 PM
    If you can get a hold of the CAD plans in .DWG format and use the RF planner would give you a pretty good number of APs to start with..
  • 12.  RE: AP105 in warehouse deployment
    Posted Apr 17, 2012 07:24 PM
  • 13.  RE: AP105 in warehouse deployment
    Posted Apr 19, 2012 11:42 AM
    cjoseph - great article. Do they have one for academic and residential dorms at university?
  • 14.  RE: AP105 in warehouse deployment
    Posted Apr 19, 2012 04:22 PM
    Nothing that specific, but you can find the answer to most here:  http://www.arubanetworks.com/technology/reference-design-guides
