  • 1.  AP124 bridging
    Posted Feb 23, 2012 03:42 PM
    I am trying to bridge two AP124's I set up a profile in "Bridge" mode and to test I am connecting a PC into the second ethernet port to see if I am getting a valid DHCP address but I am not. The controller is a 3400 and I do not have Control Panel Security enabled.
    Thanks In Advanced
    Marc
    #3400
  • 2.  RE: AP124 bridging
    Posted Feb 23, 2012 05:37 PM
    What is the enet 1 port configuration on the ap-group ?
    also what is the native vlan id in the ap-system profile ?
  • 3.  RE: AP124 bridging
    Posted Mar 02, 2012 01:55 PM
    Hi Vkumaar
    The Native vlan ID is 1 and the port configuration is using the default. Should I be setting the bridge role on both ports?
    Thanks You
  • 4.  RE: AP124 bridging
    Posted Mar 02, 2012 02:12 PM
    Can you create a "dummy" vlan in the controller and assign it to native vlan ID.
    Your enet 1 wired ap profile should look like this
    ap wired-ap-profile <profile name>
    wired-ap-enable
    forward-mode bridge
    switchport mode access
    switchport access vlan <vlan-id>
    trusted
    broadcast
  • 5.  RE: AP124 bridging
    Posted Mar 08, 2012 10:07 AM
    vkumaar,
    Thank you! I am now getting a valid DHCP address the issue i'm having now is that even though I have an address I have no internet connection. I set up a new AAA profile with log on authentication but that did not work.
