AP125 continuous reboot
  • 1.  AP125 continuous reboot
    Posted Jul 31, 2014 11:08 PM
    Just received a used AP125, used factory_reset to do its thing.
    It's just sitting onthe bench, with Putty attached to the Console interface. It's just searching for a BOOTP device by the look of it, over and over again (see extract below).
    But the question is: Every now and again it reboots the OS. Is this by design, as in a watchdog reset because it can't boot? Or does the AP have a fault?
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.08.01 13:10:35 =~=~=~=~=~=~=~=~=~=~=~=
    APBoot 1.0.8.3 (build 20343)
    Built: 2008-12-27 at 17:03:46
    Model: AP-12x
    CPU:   OCTEON CN50XX-SCP revision: 1
    Clock: 500 MHz, DDR clock: 333 MHz (666 Mhz data rate)
    Power: DC
    POST1: mem 0 mem 1 mem 2 mem 3 passed
    POST2: mem 0 mem 1 mem 2 mem 3 passed
    DRAM:  64 MB
    Flash: 16 MB
    Clear: done
    BIST:  passed
    PCI:   PCI 32-bit; scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           03  00  168c  ff1d 00002   01 80000000 00000000 00000000 00000000
           04  00  168c  ff1d 00002   01 80010000 00000000 00000000 00000000
    Net:   en0, en1
    Radio: ar9160#0, ar9160#1
    Hit <Enter> to stop autoboot:  2  1  0
    Checking image @ 0xbed00000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf500000
    en0:Down   1Gbs Half duplex, (port  1)
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    BOOTP broadcast 4
    BOOTP broadcast 5
    Retry count exceeded; starting again
    en1:Down   1Gbs Half duplex, (port  0)
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    BOOTP broadcast 4
    BOOTP broadcast 5
    en0: Down  10Mbs Half duplex, (port  1)
    BOOTP broadcast 1
    en0: Down   1Gbs Half duplex, (port  1)
    BOOTP broadcast 2
    BOOTP broadcast 3
    BOOTP broadcast 4
    BOOTP broadcast 5
    BOOTP broadcast 1
    BOOTP broadcast 2
    BOOTP broadcast 3
    BOOTP broadcast 4
    BOOTP broadcast 5
  • 2.  RE: AP125 continuous reboot
    Posted Jul 31, 2014 11:23 PM
    can you enter in the boot and run this
    clear os
    then  issue
    reset
    How does the AP finds the Controller? by DNS? static?
    Cheers
    Carlos
  • 3.  RE: AP125 continuous reboot
    Posted Aug 01, 2014 01:45 AM
    Hav
    clear os
    then  issue
    reset
    Cheers
    Carlos
    Thanks for the suggestions.
    Have tried this.
    Also tried method shown here:
    http://geekbuddy.blogspot.com.au/2011/12/how-to-reset-aruba-networks-ap105-to.html
     Am still testing, but it looks like it's still rebooting. Will keep testing.
  • 4.  RE: AP125 continuous reboot
    Posted Aug 01, 2014 03:18 AM
    Hello
    You need to investigate if you got a controller
    You cannot use the AP 125 without a controller.
    When you find out the controller and know the ip address of it and have access to it then we can continue to make this work
    We need to know ifyou got licenses  and all that.
    So the first step would be
    1-Find the controller
    2-Get access to it
    Cheers
    Carlos
  • 5.  RE: AP125 continuous reboot
    Posted Jan 13, 2015 03:31 AM
    sir, how to find the controller?
  • 6.  RE: AP125 continuous reboot
    Posted Jan 13, 2015 07:00 AM
    please start a new thread for a new question. i also see you started a thread about an instant AP, if that is related to this one, please stick to that thread and let this one rest.
  • 7.  RE: AP125 continuous reboot
    Posted Aug 01, 2014 12:54 AM
    First question, do you have a mobility controller?
  • 8.  RE: AP125 continuous reboot
    Posted Aug 01, 2014 01:46 AM
    Thanks for the reply.
    This AP have just been factory reset, is sitting on bench not connected to anything but Console. Not sure if we have such a controller, and if we did I would not have access.
    Cheers,
  • 9.  RE: AP125 continuous reboot
    Posted Aug 01, 2014 03:04 AM
    the AP isn't booting, because there is valid OS image in both flash 1 and 2.
    The AP checked that, you can see it in your console output.
    Thomas
  • 10.  RE: AP125 continuous reboot
    Posted Aug 01, 2014 03:26 AM
    That will help you:
    1.) Download the APBoot-Image from Aruba Networks
    Download Software -> AP Boot Image -> AP-12x
    filename: ap12x-1.0.0.9-18209.ari
    (If you are not able to download it, ask Aruba TAC if you can get it, I am not sure if I am allowed to give it to you.)
    2.) Place the file into a TFTP-Server (root-level)
    3.) Connect to the AP-12x and via console
    Connect an Cable to ETH0
    4.) Boot the AP and stop the autoboot hitting ENTER.
    5.) Request a DHCP-Paket manually
    apboot> dhcp
    OR
    set the ip addess manually
    setenv ipaddr <addr>
    setenv netmask <mask>
    setenv gatewayip <gateway>
    save
    (You can test the connectivity to the TFTP-Server via a ping command after that.)
    6.) Upgrade the boot image
    apboot> upgrade boot <ip_tftp_server>:<filename>
    e.g. apboot> upgrade boot 192.168.10.10:ap12x-1.0.0.9-18209.ari
    7.) boot the ap
    apboot> boot
    I attached  the technical bulletin.
    Thomas
    Attachment(s)
  • 11.  RE: AP125 continuous reboot
    Posted Aug 04, 2014 07:11 PM
    Thanks all for responses.
    I have had the AP on the bench for a couple of days now. The rebooting of the OS happens every 7 or so pages of Putty log, so I'm assuming it's a by-design watchdog occurring because it's finding no servers.
    So next I will connect it in the real world (Aruba 6000 / RADIUS), get it configured currectly, and see if it still reboots.
  • 12.  RE: AP125 continuous reboot
    Posted Aug 19, 2014 09:54 PM
    Just to confirm - the AP has been running configured on its Aruba 6000 for a week no with no reboots.
    So it would seem that the repeating OS reboot is by design, or a bug that only appears when the AP is not configured and working as expected.
  • 13.  RE: AP125 continuous reboot
    Posted Aug 20, 2014 12:02 AM
    correct, that is by design.  If the AP cannot find a controller it will continually reboot and try again.  Similarly, it it does not get an ip address (necessary to find a controller), it will just reboot over and over.
