  • 1.  AP135 console parameters
    Posted May 27, 2013 10:26 AM
    Dear all:
    We are working on a new installation AP135 / AP105 and S3500 having a remote controller.
    All AP105 are reachable thru the console port 9600-N-8-1, nevertheless connecting the same cable using the same parameters to the AP135 doesn't work.
    Any clue ?
    Nelson
  • 2.  RE: AP135 console parameters
    Posted May 27, 2013 10:40 AM
    Make sure you are connecting to the serial port ;)
  • 3.  RE: AP135 console parameters
    Posted May 27, 2013 10:58 AM
    Sure !
    In fact, unplugging the connector from one AP105 to another I got immediate response in the TTY terminal, but doesn't happens the same when connected to the AP135
  • 4.  RE: AP135 console parameters
    Posted May 27, 2013 10:59 AM
    Okay.  Try a different AP-135.  It should work exactly the same as the 105.  Make sure you have no flow control on...
