According to the guide, if the radio led of 2.4GHz is on -amber , it means 2.4GHz radio enabled in non-HT Wlan mode.
Below is the power specifics of AP205 for your reference.
• Maximum (worst-case) power consumption: 12.5 watts
(PoE) or 11.7 watts (DC)
• Maximum (worst-case) power consumption in idle mode:
8.4 watts (PoE) or 7.7 watts (DC)
• Direct DC source: 12 Vdc nominal, +/- 5%
• Power over Ethernet (PoE): 48 Vdc (nominal)
802.3af-compliant source
• Power sources sold separately
• When both power sources are available, DC power takes priority
Dongqing Li
Original Message:
Sent: Feb 03, 2021 11:05 AM
Subject: AP205 Amber 2.4GHz light, lost connections
I have a single 205 that periodically drops all clients and displays a solid amber 2.4GHz light. The only way to restore connections is to reboot. I thought perhaps it was bad, so I swapped it out for another 205 I had, but the replacement did the same thing. If it matters, this is the only of my access points that is set up as Mesh point, and it is the only one that is powered by DC rather than PoE. Could it be power-supply related? What else should I check?
Richard Spaulding
