AP228: Micro USB to RJ45 serial rollover?
  • 1.  AP228: Micro USB to RJ45 serial rollover?
    Posted Aug 25, 2016 03:15 PM
    I need to get console access to a 228AP through a serial console server (not through a laptop and USB) using a RJ45 rollover cable.  The 228AP has a micro USB port.
    Is there a preferred/recommended cable for converting micro USB to RS232 either through a DB9 or RJ45 (preferred) connection?
    Do the Cisco USB to RJ45 rollover cables work for Aruba APs?
    https://www.amazon.com/dp/B00M2SAKMG/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687762&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B00GN5OIK4&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=6ZJTB44H11CRBS5FC9NN
