  • 1.  AP505 virtual controller with AP group creating.
    Posted Feb 06, 2025 05:44 AM
    I install AP505 for 10 set. Now I assign 5 SSID with it. It work well. However, I need to create profile to fill with different SSID such as
    1st profile = SSID 1-3  = use with AP 1-5
    2nd profile = SSID 4-5 = use with AP 6-8
    3rd profile = SSID 1,3,5 = use with AP 9-10
    I can do it with aruba 6xxx model but for virtual controller , I can' find where is gui in a menu(attachment) for create profile and how to apply that profile to AP. Could anyone suggestion will be pleasure.
  • 2.  RE: AP505 virtual controller with AP group creating.
    Posted Feb 07, 2025 10:29 AM
    You need to take a look at zones, the topic is available in the user guide.
    Carson Hulcher, ACEX#110
  • 3.  RE: AP505 virtual controller with AP group creating.
    Posted Feb 07, 2025 06:51 PM
    you can refer to Configuring Zone Settings on an Instant AP
  • 4.  RE: AP505 virtual controller with AP group creating.
    Posted Feb 07, 2025 10:14 PM
    Yes, I look at that manual and apply zone, yes, its work like a charm. Thank you.
