Hi there,
I've got a AP515 on a Cisco switch with 15.4W:
Available:370.0(w) Used:15.4(w) Remaining:354.6(w)
Interface Admin Oper Power Device Class Max (Watts)
Fa0/10 auto on 15.4 Ieee PD 4 15.4
I don't get in online with IPM configured:
Power Status
Item Value
Power Supply : POE-AF
LLDP Power : Successfully negotiated at 13.0W
Current Operational State : 1 ETH port disabled; USB power disabled; All radios disabled
Eth0 HW POE status : POE AF, LLDP power: 13.0W
Following IPM Config is active:
ipm-power-reduction-step-prio ipm-step disable_usb priority 6
ipm-power-reduction-step-prio ipm-step disable_alt_eth priority 5
ipm-power-reduction-step-prio ipm-step radio_2ghz_chain_2x2 priority 4
ipm-power-reduction-step-prio ipm-step cpu_throttle_25 priority 3
ipm-power-reduction-step-prio ipm-step cpu_throttle_50 priority 2
ipm-power-reduction-step-prio ipm-step cpu_throttle_75 priority 1
Is there anything I can do?
#AP515
