  • 1.  AP535 Power (POE)
    Posted Jul 21, 2020 08:28 AM
    I have been testing an AP-535 and noticed it wasn't broadcasting any SSIDS.
    So I checked in the system logs and I am seeing this message:
    Jul 21 13:12:50 :305061: <7178> <WARN> |stm| sapm_override_ap_radio_prof: AP BFS-AH-FLOOR3-AP01-XXXXX: Disabling radio 0. Power profile is POE-AF
    Jul 21 13:12:50 :305061: <7178> <WARN> |stm| sapm_override_ap_radio_prof: AP BFS-AH-FLOOR3-AP01-XXXXX: Disabling radio 1. Power profile is POE-AF
    This is plugged into a Cisco 2960-X switch (One port only) and I believe I have enabled LLDP.
    Can you confirm if I need two ports to power this device correctly? Or if there is something I am missing on the switch or controller which is causing me this error?
    Scott
  • 2.  RE: AP535 Power (POE)
    Posted Jul 21, 2020 09:08 AM
    Actually believe I got this working it is now broadcasting my SSIDS.   I had to enabled LLDP on the whole switch rather than the interface.
    So it seems it can be powered from one ethernet port on the 2960-X as long as LLDP is enabled on the switch to transmit and receive.
  • 3.  RE: AP535 Power (POE)
    It only requires a single connection.  What is the configuration on the Cisco port?
  • 4.  RE: AP535 Power (POE)
    Posted Jul 21, 2020 09:19 AM
    I had the lldp med-tlv-select power-management on but i hadn't enabled the lldp transmit and receive on the port - so this is probably why it wasn't working?
  • 5.  RE: AP535 Power (POE)
  • 6.  RE: AP535 Power (POE)
    Posted Jul 21, 2020 11:02 AM
    The fix on that thread was to disable the "no lldp tlv-select power-management"  however I never had this on to begin with.  The fix for me was to enable lldp on the switch using the command: lldp run
    I then enabled lldp transmit and lldp receive
    It then seemed that the switch was able to send the correct power to the port and the AP therefore did not disable the radios.
    Port Description: eth0
    System Name: BFS-AH-FLOOR3-AP01-XXXXX
    System Description:
    AOS-W (MODEL: OAW-AP535), Version Aruba AP
    Time remaining: 97 seconds
    System Capabilities: B,W
    Enabled Capabilities: W
    Management Addresses:
        IP: XX.XX.XX.XX
    Auto Negotiation - supported, enabled
    Physical media capabilities:
        1000baseT(FD)
        Asym Pause(FD)
        Pause(FD)
        100base-TX(FD)
        Other/unknown
    Media Attachment Unit type: 30
    Vlan ID: - not advertised
    PoE+ Power-via-MDI TLV:
     Power Pair: Signal
     Power Class: Class 4
     Power Device Type: Type 2 PD
     Power Source: PSE
     Power Priority: unknown
     Power Requested: 25500 mW
     Power Allocated: 25500 mW
