What is radio resets and beacon stuck at the radio ?
16 Consecutive Beacons could not be sent out over the air.
This could happen due to various conditions ranging from very high channel utilization (hence no opportunity for channel access to send the packet out) or due to some internal conditions in the radio.
Our automatic recovery mechanism is to do a radio reset. You may want to monitor the channel busy radio stat and noise floor to get an idea, if this is happening quite often.
When this condition is detected, the chip is reset and the problem goes away. This is not a serious problem if this does not happen frequently.
Is this happening continuously? Could you check send the channel busy stats?
In the event of a stuck beacon and radio reset, what effect (if any) does the client experience? Do they get dropped during a radio reset?
No.. but they may look for other APs because of no beacons from current AP.
Please provide the output of show ap debug radio-stats ap-name <name of the ap>
Thanks.
