I tried to get full configuration of a mobility conductor on 8.12.0.3 version
I have no issue with command : curl --insecure -b "aruba-cookie" -d "username=admin&password=password" https://device:4343/v1/api/login
After it is impossible to have an answer with this kind of command : curl --insecure -X GET --header "Accept: application/json" --header "X-CSRF-Token":"XXXXXX" "https://device:4343/v1/configuration/object/config?config_path=/mm/mynode&type=local"
The hierarchy of two devices is
Config Node Type Name
/ System
/mm System
/mm/mynode System
the answer is only a web page then my request is not correct but I don't understand why.
Thanks in advance
Cécile
