Have you checked to see if "Private Wi-Fi Address" is enabled in the SSID settings on the iOS device? (Settings > Wi-Fi > SSID blue i button > Private Wi-Fi Address)
If enabled it will generate a virtual MAC address to use. If it is not enabled, it will use the actual device wireless MAC. That can also be found under general settings (Settings > General > About > Wi-Fi Address)
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
Original Message:
Sent: Aug 25, 2022 09:13 AM
Subject: Apple devices not able to connect to SSID via MAC authentication
We are not able to connect using iPhones / iPad (All apple devices) to SSID while using MAC authentication,
MAC Authentication is getting denied state.
Any articles or posts could help me solve or understand the reason.
Thank you.
Eyad Subeh
