in the v-lan context you can also use mac based ACLs to reglement L2 traffic.
On interface v-lan context, you typically will filter only routed traffic.
Check this: AOS-CX 10.13 ACLs and Classifier Policies Guide for 6300, 6400, 8360 Switches
(config)# interface vlan 20
(config-if-vlan)# apply access-list
ip Internet Protocol v4 (IPv4)
ipv6 Internet Protocol v6 (IPv6)
(config-if-vlan)# apply access-list ip
NAME The ACL name (maximum 64 characters)
(config-if-vlan)# apply access-list ip aa
routed-in Routed inbound (ingress) traffic
routed-out Routed outbound (egress) traffic
VS
(config)# vlan 20
(config-vlan-20)# apply access-list
mac Ethernet MAC Protocol (MAC)
(config-vlan-20)# apply access-list ip aa
in Inbound (ingress) traffic
out Outbound (egress) traffic
Best regards, mom
Original Message:
Sent: Nov 27, 2023 02:42 AM
Subject: Apply access-list to VLAN or to VLAN-interface
using the AOS-CX operating system there are 2 ways to apply ACLs to VLANs:
in the VLAN interface context: apply access-list ip NAME routed-in
OR
in the VLAN context: apply access-list ip NAME in
Can anyone explain what the difference is? My guess is that to apply ACLs between VLANs I should probably apply them on the VLAN interface.
Steven
