There are various reasons for dropped connections and very slow speeds
You can check the settings like SSID Datarates, Interference, Channel width, AP Transmit power, and AP uplink statistics
Harendra | ACEX165 | ACEP | CWDP | CWSP
If you find my answer useful, consider giving kudos and/or mark it as the solution.
Original Message:
Sent: Jun 12, 2025 08:49 PM
Subject: APs and AMs in same vlan?
Having an issue in a building where we just installed WiFi. 4 AP-635s in AP mode and 1 AP-535 in AM mode.
having issues with dropped connections and very slow speeds. I noticed on the PoE switch that all 4 APs and the 1 AM are all on the same vlan, which is not how it's supposed to be.
obviously , going to correct this, but just curious. Would this be the cause of our poor connection issues? And if so, why
