So i'm working on an interesting setup and noticing some connectivity issues with users. We have an LTE connected router with a switch and a couple AP-325's attached. The Router is connected via VPN back to our network and connects to our controller pair at our Data Center. The Controllers are 7220's running 6.4.4.16 code.
In testing, I found that the AP keeps failing between the primary and backup HA members constantly - causing users to not get connected to the controller or get an IP address. I also think the BSSIDs keep resetting each time, which may be normal and expected as it rebuilds it's GRE tunnel.
My question is can I adjust the HA failover values / timeouts for these specific APs? Is there any concern over MTU values if it's a Campus AP going over a VPN (I don't know MTU value on VPN). Any other suggestions to help stabilize the APs?
As as FYI, there is no packet loss is high latency when hardwired to the switch with a PC.
Thanks for the help
