Apologizing if this an RTFM kind of situation but I just was unable to find good instructions online. Followed the 8.2 and 8.9 John Schaap Video's instead.
Each time when I activate L2 clustering on my Aruba Virtual Controllers I am losing connectivity to my access-point(s). I am using AOS: 8.10.0.14_90752
Here's an overview of the setup all running on ESXi although the switch below it is a hardware switch where the AP connects to
VLANs used on Controller:
Ge-0/0/0: access ports with VLAN 201
Ge-0/0/1: trunk port with VLAN 202 and VLAN 25 (data VLAN for clients)
I use an untagged VLAN for my APs and a tagged VLAN for the clients (25)
I followed the instructions and created a cluster group.I tried two methods, one time like below, basically only setting the VMC IPs no groups or anything else.
The other time I set the group and added the VRRP-IPs for CoA
Here's the VRRP configuration
Whenever I set the cluster-profile at the Controller level everything goes south and I loose connectivity to the APs.
Anyone have a suggestion for me? Thanks in advance
Martijn van Overbeek
Architect, Netcraftsmen a BlueAlly Company
