I don't see it in the
Aruba Instant VRD. Personally I would avoid multi-homing of Instant APs, unless absolutely required.
Original Message:
Sent: Sep 08, 2022 05:05 AM
Subject: APs not coming up after update
Are there any references about the correct LACP configuration between Aruba APs and switches to avoid this issue everytime the Instant cluster is updated?
Original Message:
Sent: Aug 15, 2022 07:22 PM
@cjoseph Thanks for the tip, I got them back up and running by disabling eth1.
Am I running an unsupported configuration or do I have a faulty configuration? They have been running without issues for a long time, but I do remember having a similar problem the last time the system was updated. Even now half of the APs are still unchanged with both ports enabled and LACP configured on the switch side and they came back up normally after the update. So I'm a bit confused what caused the issue and how to avoid it in the future, while hopefully keeping redundancy and load balancing.
Original Message:
Sent: Aug 15, 2022 06:34 PM
Make sure you only have a single ethernet, ethernet 0 plugged in, at a time.
Original Message:
Sent: Aug 15, 2022 06:26 PM
I managed to login to three APs, one doesn't seem to even get an IP address.
Here are the system logs for the three, with some name and address info redacted:
https://pastebin.com/PKNrrR8r
https://pastebin.com/rsRzvqyA
https://pastebin.com/PyayJV3c
Looks like they had some trouble with the DRT update. I was able to get another one back up by shutting down other ones. So seems like there's some conflict.
Original Message:
Sent: Aug 15, 2022 05:33 PM
See if you can ping/ssh into the aps that did not come up. Login to them and type "show log system"
Original Message:
Sent: Aug 15, 2022 04:37 PM
I was updating a cluster consisting of three 325's and five 535's from firmware 8.7 to 8.9 using the web interface. After a reboot I also updated the regulatory version.
Not all APs came back after the update even after waiting about half an hour, so I restarted the ones that were up. After this some more APs came online, but not all and not the same ones as before. Six of the eight were up.
I rebooted them a second time and this time only four out of eight came up. Any ideas what to do or am I facing a wipe and restore?
