Pretty sure those two v1 zl Modules (J8702A and J8706A) are supported on HP 5400 zl Switch series...it's a matter to find an old [*] QuickSpecs document (first references go back at least to 2006, so 11 years ago): probably HP, revising the QuickSpecs along the years, simply removed or, better, superseded them (so replaced) by newer and better performing ones (indeed read their EoS announcement here).
HPE Portal with EoS End of Sals information (recent and legacy announcements) is here.
There are some good official HPE explanining documents about v1 zl, v2 zl and v3 zl2 Modules and their relationship with 5400 zl and 5400R zl2...also there is a document about differences between those Modules' versions with regard their usage on newer Aruba 5400R zl2 Switch series (Feature Set: Compatibility mode versus v3 Mode Only).
[*] an HP ProCurve 5400 zl Switch series's QuickSpecs reporting the J8702A and J8706A as supported (early 2006) can be found here: please note how the ver=1 on the URL goes up to ver=41, what that means? it means that 41 QuickSpecs revisions were published between early 2006 and 2016 (inbetween HP changed into HPE lately)...last ver=41 is the latest published QuickSpecs for the HPE 5400 zl Switch Series.
